Meraki ZR4
gmorisak
Meraki ZR4
 Can anyone tell me how to add a Meraki ZR4 to the dashboard?  I am trying to add it to a Cisco network as a remote worker and can't find a way to connect.
5 Replies 5
RWelch
Configure your Dashboard Network
The following is a brief overview only of the steps required to add an Z4/Z4C to your network. For detailed instructions about creating, configuring and managing Meraki networks, refer to our Managing Dashboard Networks document. Additional resources can also be found via: documentation.meraki.com.
  1. Login to http://dashboard.meraki.com. If this is your first time, create a new account.
  2. Find the network to which you plan to add your Z4/Z4C or create a new network.
  3. Add your Z4/Z4C to your network. You will need your Meraki order number (found on your invoice) or the serial number of each Z4/Z4C, which looks like Qxxx-xxxx-xxxx, and is found on the bottom of the unit. You will also need your Enterprise license key, which you should have received via email.
  4. Go to the map / floor plan view and place each Z4/Z4C on the map by clicking and dragging it to the location where you plan to mount it.
Adding and Removing Devices from Dashboard Networks
Z4/Z4C Series Hardware Installation Guide
gmorisak
Thanks.  My issue seems to be that my device is not in inventory so I can choose from the existing devices, I only have the option to claim a device.  I need to figure out how to add my device to a network.
RWelch
Good luck!
https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Adding_and_Removing_De...
Take a look at the documentation.
Take a look at the quick guide start.
https://documentation.meraki.com/MX/Deployment_Guides/Z3%2F%2FZ4_Quick_Start
