Meraki Wireless + Zyxel Repeater
AnMo
Hello All
For 1 technical device, i should extend my Meraki WLAN.
I have an Zyxel WRE6605.
Could i, or how can i configure the Meraki WLAN to accept the Zyxel repeater?
ConnorL
Meraki Employee All-Star
There's nothing to configure on the Meraki side, the AP should in theory just treat the extender as a client.
Word of caution about repeaters though, whilst they do boost coverage they're usually pretty detrimental to bandwidth, so I would avoid using them where possible.
AnMo
Thanks. I will try it.
I need it for a heating system. There i cannot make a LAN connection.
So i try to extend my WLAN on a cheap and easy way
AnMo
