Meraki Wireless DHCP service custom 119
mrjelly
I am looking to use the DHCP option 119 to have a list (of 2) to set DNS suffixes.
Would the text structure be: 'example.com','one.example.com' ?
I currently have an option 15 set, and need to give out multiple DNS suffix options
Try converting each domain to text in hexadecimal format, and then combining both into a single hexadecimal string.
mrjelly
Thanks, does there need to be any other characters or just the domains in one long hex string?
Just the domains in one long hex string.
Ryan_Miles
