Meraki Wifi SSID - Show key not an option.
Techsup
Hi there all, I'm trying to find out what the wireless password would be and the password is hashed out, show key is not an option for me. Please can you advise if this is due to permissions or am I looking in the wrong place. Thanks.Wireless.png
I just tried it as an Organisation Admin in Chrome, and I could see the "Show key" button.
If you are not using Chrome, perhaps try that.  Otherwise it sounds like you might need to be an Organisation Admin to retrieve the key.
it should be right next to it. probably a permissions issue. your not admin but on read only permission?  if your admin try another webbrowser
Techsup
Thanks for the replies. I tried in all browsers firefox\ie\chrome and had the same issue. After looking into this further it turns out that I have only have read permissions on the org.
