Meraki WiFi Offline Clients
Tom7021
Struggling to find an answer on this one. Does anyone know how long a Wireless Client should still show for in the Clients list after it has gone offline and is there a way to change the duration?
Struggling to find historic data at the moment.
30 days, and you can't  increase it.
https://documentation.meraki.com/General_Administration/Privacy_and_Security/Cloud_Data_Retention_Po...
6 Replies 6
Tom7021
Thanks, although I don't seem to get more than 24 hours. If I sort my Client list by Last seen, you can see the below:
I'm offsite today, but yesterday one of my mobile devices would have been connected in the morning and I can no longer see that.
Should I be looking somewhere else to see 30 day history?
Vinisha
It's this option on the top:
let me know if it worked..
Tom7021
Literally saw that after posting this, why are the simple things always the hardest!
Thank you 🙂
Madhan_kumar_G
you should be able to pull out data upto 90 days historic. If more that that retention is required, only option is to have a syslog server.
Tom7021
I missed the obvious drop-down "for the last 30 days"! Apologies, I think I need my eyes tested!
Also found the Event log which is quite useful, having not needed to do this type of work before I hadn't looked.
Thank you for your help 🙂
