Meraki MR76 AP doesn't start up
Eugenijus
We have purchase a lot of MR76 APs lately to expand / upgrade our Wi-Fi networks on two sites. Most of them were setup and installed ok, however I received one device from another site that is not loading up.
Short description. Meraki AP MR76 LED light flashes in all different colours, then stops on orange light for a minute or so before another round of changing colours. AP is connected to Meraki MS 125-48LP, we have tried a few different Meraki switches at original site with same result. Sometimes switch shows that there is a PoE device connected and power consumption, however there is no data usage at all. Sometimes switch shows port disconnected. I assume AP is rebooting itself continuously.  AP is claimed to dashboard, it was connected to the dashboard at initial install, because dashboard says "Unreachable for about 1 month". That means AP was working ok for a short while, but developed a fault afterwards. I tried to push "Factory reset" button, but that didn't make any difference.
I wonder what can I do to troubleshoot it further. Can I try to reload firmware while connected AP to PC? I have PoE injector that would allow me to power on AP and same time connect it directly to PC.
Any advice is appreciated.
rwiesmann
i guess since you made already a factory reset, which did not help, I would proceed with Meraki Support.
Just open a support Case and the guys will check what they can do.
Kind of had a similar issue...did what i could do and opened an support case, which ended in an RMA.
Hope that helps
6 Replies 6
Do you have a firewall that could be blocking communication with the Meraki Cloud?
Eugenijus
Hi Alemabrahao,
We have a lot of other Meraki APs MR76, MR74, MR46/E on both sites. Other devices are communicating ok through same firewalls.
rwiesmann
Hope that helps
Baah-O-Baah
You will not be able to update the firmware by connecting to a PC. The device should get an IP, connect to the Meraki cloud and fetch any updates available.
It may be stuck anywhere in that process. A factory reset should get it to try the above once again. If the issue persists, give support a call.
Cheers.
Configure a switch port so that you can just plug in a notebook and it can access the Internet without issue.
Now plug in the MR into that same port using the same patch lead.
If it doesn't start working, check out the local status page and see if it offers any hints.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
Otherwise it might be a faulty MR, and you'll need to open a support case.
Eugenijus
I contacted Meraki Support and after all tests done received a replacement unit. Thanks for all replies.
