Meraki MR windows Rdp issue
kdm_korean
hello
dear teachers
One problem occurred.
I am using MR 56, and some clients are disconnecting when using Windows rdp.
Has anyone faced a similar problem?
i need help
thank you
7 Replies 7
TBHPTL
Not enough information to assist.  Very basically, if your clients have IP addresses the issue isn't your wifi, it lies elsewhere.
jfigueroa
Hello, kdm_korean.
Can you please validate that when using which SSID via wireless you are experiencing disconnects?
1. Are you using windows RDP or Chrome RDP?
Thanks.
TBHPTL
his post stated Windows RDP...
jfigueroa
thank you for responding, but is also a fact to know how the firewall rules are in place for the Corp SSID and Guest SSID from WAN to LAN base on the MGT. We will need to trace the path of how things are put together since not users are being affected by this issue.
kdm_korean
hello
Thanks for replying
Currently, Windows RDP is an internal communication, so there is no firewall setting.
Of course, there are no Meraki firewall settings.
kdm_korean
I tested it again
It works normally in a psk environment, but wifi is disconnected when rdp is accessed during 802.1x authentication.
What could be the cause?
rdominguez
Hello @kdm_korean, have you opened a case with Meraki Support on this topic? If not, I would recommend doing so. Meraki Support will most likely request live troubleshooting and perform packet captures in an effort to find a root cause.
