We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
I am wondering if the GR10 or GR20 allows you to mesh them so the remote AP does not require an ethernet connection for it's up. Like an UniFi AP?
Should the Meraki GO not have this ability do the regular Meraki have this?
Solved! Go to solution.
Yes Go also support mesh
https://documentation.meraki.com/Go/Meraki_Go_-_Wireless_Meshing
