Actually - there might be a way to disable it after all.....go to
Organization > Alerts
Select Configure alerts in the RH corner.
Search for Ethernet uplink speed degraded
Uncheck Enable alerts
Be sure to hit Save. This doesn't get the BONUS points you were wanting based on specific sites or areas unfortunately.
