It is reporting as Repeater because it cannot obtain a lease, not vice-versa.
According to documentation:
The AP only converts to a repeater when one of the following is true:
The AP cannot receive an ARP reply packet from the default gateway on the LAN which is usually a local firewall or router
The AP is unable to obtain a valid IP address via DHCP
The most common problem: check the cabling.
