@PhilipDAth wrote:
802.11r improves roaming by helping the client find other APs that it can roam to. 802.11r got a bad rep because of many security issues. The security issues are less severe when using it with 802.1x.
"Adaptive" mode only uses it with clients than can support it - but often not all clients that can support it. So you end up with lots of 802.11r capable clients not using 802.11r.
Phil I think your thinking of 802.11k? And for reference to the original poster, all that KRACK stuff has been patched if you were curious:
https://documentation.meraki.com/zGeneral_Administration/Support/802.11r_Vulnerability_(CVE%3A_2017-...
802.11r (kind of like OKC but even faster) will have a client do a full EAP authentication, and then cache the PMK on all the other access points (much more complicated that this but for simplicity sake lets not go into super details). Important note here since there is no WLC with Meraki, is that Meraki requires those AP's to be on the same L2 domain (same subnet basically). End-goal being that when the client does roam from AP to AP, he doesn't have to do a full EAP authentication all over again (which takes forever in the wireless world), and the process is now just 4 frames, with the 4 way handshake being 'baked' into the authentication and reassociation frames.
1. Authentication Request
2. Authentication Response
3. Re-association Request
4. Re-association Response
For reference, OKC (which Meraki supports/is enabled by default), would look as such:
5. EAPoL Key Message 1
6. EAPoL Key Message 2
7. EAPoL Key Message 3
8. EAPoL Key Message 4
On the Cisco WLC side, they have a 'mixed mode' for 802.11r so that clients that do support it, will use it, and clients that don't will not. This is great because the single SSID can serve both types of clients (presumably without issue).
I've honestly never bothered with 802.11r on the Meraki side yet but this thread is making me want to test it more now lol.
Phil correct me if I am wrong but the only documentation that I can find for 'Adaptive Mode' is that it is strictly for iOS 10 devices to benefit from 802.11r and that's basically it. Not sure if another device type that does support it would use it or not. Would have to ask support because their documentation seems lacking on this insight.
