Meeraki MG21 as backup
Manucha
Hi Everyone,
Could someone recommend good options for cellular data plans to be use as back up lines that will be compatible with MG21.  Is Google Fi a good choice.  I am moving away from Hologram due to high cost and devices getting disconnected randomly.
Thanks a bunch
1 Reply 1
If it is plugged into an MX and used as a backup-only link, it will use around 100MB of monthly traffic.
