MX65W and USB dongle support in Australia
wifinut
I was wondering if the Meraki MX65W supports "non-standard" USB 4G dongles such as Huawai:
https://www.amazon.com/product-reviews/B0711S4T9J/ref=cm_cr_arp_d_hist_5?ie=UTF8&filterByStar=five_s...
We're thinking of using this as a pop-up Wifi solution in Sydney, Australia.
2 Replies 2
On the whole, I would recommend you use the 4G Hotspots - that have Ethernet ports on the back, and just plug it into the standard WAN port on the MX.
MilesMeraki
I second @PhilipDAths recommendation. I've found this a lot more reliable than using a USB dongle.
