MR76 with downtilt Antenna
JGR
Just browsing
hello guys
I have a question about antenna selection for Access Point MR 76.
I need a downtilt antenna for coverage of a production and warehouse hall ( dirty , dusty outdoor conditions). The antennas can only be mounted on the ceiling at 8m height.
Actually the antenna MA-ANT-3-D6 would fit well for this. But according to the datasheet it is not compatible with MR76. But I need an access point for rough environment.( not the MR46e)
The only alternative is ANT-20.
Does anyone have an idea ?
1 Reply 1
Inderdeep
@JGR : Check this out. The compatible antennas: MA-ANT-20/21/23/25/27 with MR76
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR76_Datasheet
www.thenetworkdna.com
