- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MR76 & external antenna's
I have a customer who has today old Cisco AP's but with ANT2544V4M-R (installed in a fridge) - I plan to use the MR76 but can I use this antenna on my MR76 ? there is no equivalent on the MR76 datasheet only patch and sector antenna's
Any idea ?
Thank you
jean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
List of compatible antennas for MR76
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR76_Datasheet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi thank you for you replay - I see it but only patch and sector antenna's but no dual-band omni with long coax cable to leave the AP outside of the fridge -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Something to think about - have you considered going to an all-in-one AP like the MR78? Being so much newer than the old APs - it is likely to provide a lot more coverage.
Having no external bits and being IP67 rated will make it almost bullet proof in a fridge. It will make washing it down much easier as well (assuming they need to do this for feed hygene reasons).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi - thank you for the feedback it could be a good solution - I need just to check with the customer the lowest T° the fridge can go - thx again !
