- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MR66 questions
We have an MR66 setup in the gymnasium and I was just curious to ask the community. If I stand close to the AP no matter what I can never connect to it which is odd. There are 2 antennas which I have a picture provided. One is inside and the other is outside. Should I be able to connect to the AP from inside the gym with the other antennas? I would appreciate any advice and sorry the images flip automatically here when it uploads.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Outside seems to be using the 5GHz connectors. And it seems that 5GHz is correctly configured to being connected to a sector antenna. The 2.4GHz seems to be configured to be connected to a sector antenna too, while in reality they seem to be omni's. So yes, I'd try changing that setting for the 2.4GHz radio.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Seems like you're not actually using a sector antenna on the inside but rather two omni's. I assume those are ANT-20's? Have you tried changing the config to reflect that. It now states ANT-13 which is the 2.4GHz sector, which would be a stronger antenna and therefore the AP would tone down it's actual signal strength to avoid passing the legal limits.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@BrechtSchamp Im just even trying to see if I can have it connect inside the gym. Outside has no issues so you suggest I change antenna settings?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you @BrechtSchamp Never could get anything connected inside till this change. Now I can just leave it there.
