Do you have more than one AP attached to the MX65, if so are they both doing it? If not can you try switching one of the APs to the other POE port? Next, I'd try grabbing one of the APs and plugging it in directly to the MX with a short jumper to see if it does the same thing. That should help start tracking down if it is an AP, MX or cabling issue.
But I haven't observed that issue in my environment yet.
