- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MR36 connected devices limitation.
Hello Community,,,,Let me clarify and ask about MR 36 user/connected devices limitation. I have using MR36 12APs. In this case I would like set connected devices to each APs. For eg: Only 12 users can connected to AP1 , only 20 users can connected to AP2 like that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The only way you could achieve something like that is using different SSID's, and SSID availability to specify which AP is advertising which SSID.
However I think a fair question is what problem are you trying to tackle by implementing this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I would like to define connected device limit to each APs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That's not the way wireless infrastructure is typically designed and deployed.
Are you concerned too many devices may connect to a single AP?
If that's the case, you may need to increase the density of WAP's in that area. Or use a feature such as client balancing.
If you're concerned about bandwidth usage on an individiual AP, you can set per-client traffic shaping (under Wireless -> Traffic shaping).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can use client balancing for this matter:
https://documentation.meraki.com/MR/Other_Topics/Client_Balancing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Don't try and do that. It will create a lot of work for you.
If the APs are near each other you can try reducing the power levels to encourage roaming.
Under Wireless/Radio settings/Profiles, start by using some values like these:
