MR34 offline or not??
ChrisConnelly
I have an MR34 connected via a PoE injector.  It has power, an orange light blinking, but is not reachable from my management console.  It's also not connecting to a device.  How do I bring it back online?  I'm unable to reboot it from the console.  Is there a reset that will work?
Ryan_Miles
Meraki Employee All-Star
confirmed bad cable run
Ryan_Miles
Orange means it can't connect to dashboard.
Was it working previously?
Is the injector connected to an upstream switch or wired device?
ChrisConnelly
Yes, it was working originally.  It was connected to a PoE injector that I suspect failed.  I replaced the injector but still the same.  Upstream, the injector is directly connected to my MX250.
Ryan_Miles
DM me the AP serial and happy to take a look
Ryan_Miles
