MR30.5 is out - Many fixes !
RaphaelL
Important note
  • While Meraki APs have traditionally relied on UDP port 7351 for cloud communication, and TCP ports 80 and 443 for backup communications, with MR 28+ we are beginning the transition to using TCP port 443 as the primary means for cloud connectivity. In order to ensure proper connectivity to the Meraki cloud after this upgrade, please ensure that all “Meraki cloud communication” traffic specified in the "Help" > "Firewall Info" page is allowed through any firewalls or security devices that are deployed upstream of your Meraki APs. These requirements have been updated in November of 2022, so it is important that you review them. (Wi-Fi 6 and Wi-Fi 6E APs)
  • WEP deprecation (https://documentation.meraki.com/MR/Encryption_and_Authentication/WEP_Deprecation_on_MRs)
Legacy product notice
  • When configured for this version, MR12, MR16, MR18, MR24, MR26, MR32, MR34, MR62, MR66, and MR72 will run MR 26.8.3
Bug fixes
  • General stability and performance improvements
  • WPA3 OWE AKM suite missing in beacons
  • Incomplete configurations when using VLAN profiles
  • Intermittent connectivity loss for Windows client devices
  • When using WPN, DHCP requests are missing option 55
Known issues
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
  • In high capacity wireless networks APs may experience instability when the “Client Balancing” or "Band Steering" feature are enabled
Could that be the magic fix that I have been waiting for months !?
RaphaelL
It is not the fix that I have been waiting for !
I have been finding WPA3 unreliable.  I wonder if this might sort it out.
BlakeRichardson
I do like systems that use seperate ports for management traffic, everything using port 443 while convenient just becomes a large melting pot of traffic.
9dtinkler
Just browsing
Do we know what version(s) or what version it started in for this bug? "Intermittent connectivity loss for Windows client devices" Kind regards
