I have some clients connected to an MR16, namely an Epson printer, and some clients, and those clients are unable to connect and print.
The LAN network is configured as following:
- One MX64 as gateway
- One Cisco Catalyst switch (bui I guess it dos not matter, as it)
- Some MR16 connected to the LAN via Ethernet
- Some non-Meraki APs connected to the LAN via Ethernet, WLAN configured in bridge mode
- Some clients connected directly to the local LAN via Ethernet, or via Wi-Fi through those non-Meraki APs
- Few clients connected to the local LAN via the MR16 in bridge mode (including the printer)
- Most of the clients connected to the isolated Meraki WLAN
The Meraki WLAN network is configured as following:
- An SSID configured as isolated WLAN (Meraki DHCP via NAT)
- An dedicated SSID configured as Bridge, for printers (in order to be part of the LAN) (Layer 2 LAN isolation is disabled)
The department I'm configuring the printer has the following settings:
- One desktop connected directly to the LAN
- An MR16 connected the LAN (same segment)
- Some clients connected to the Isolated WLAN's SSID at the MR16
- An Epson printer connected to the Bridged WLAN's SSID at the MR16
What happened:
- Clients under the isolated WLAN can successfully connect to the local LAN, then, print to the mayor printers.
- Clients under the LAN (directly connected or through non-Meraki APs) can connect to the Epson printer
- However, the clients connected to the isolated WLAN's SSID are unable to connect to the Epson printer.
So, may have me an issue with the configuration, or is just a feature misconfigured?
Thanks.
