Thanks for the suggestions.  I don't think that would be the problem.  I'm not trying to get on the Meraki WiFi 10/8 network.  Once my VPN is established, my firewall should then route the connections back to my local LAN network.  I only need internet access for the VPN to work.  It works fine on my corp radius SSID, & hot spot or home internet.
Once I connect yes I can ping anything other then my local LAN network.
However if I did need to enable local LAN, will that then give any guest client access to any device on the guest Meraki DHCP network?  I don't want to do that.
What's odd is the netmotion server is a new one spun up for an upgrade.  The old one still in use connects fine from the Guest WiFi.
I must need some sort of route/policy, have to figure out where to put it.
