MR AP is not generating traffic, how i can check the same
Mohit_Dhanjal
Hi All,
I have connected my meraki MR access point with Cisco access switch, this is totally non meraki implementation, apart from AP's, we are using all non meraki devices(Switch, routers and Firewall).
After assign static IP to my meraki MR, security team is saying that, they are not getting any traffic or request generating by MR.
How i can check the same. my access point is trying to generate traffic or not.
Please share your suggestion.
Regards
Mohit Dhanjal
Brash
Do you have the MR connected to the dashboard yet or is that what you're trying to achieve?
If it's already in the dashboard, you can simply spin up an said, connect a client to it and send traffic.
If you're trying to get it connected to the dashboard, you can access the local status page (where you set the static IP) and check the connection status.
Under Access Point Details, you can see information about whether the MR can connect to the local network, the internet and the Meraki cloud.
If it has passed the initial local network, it will be sending ICMP and TCP packets to 8.8.8.8 and the Meraki Cloud. You should be able to see those on the perimeter firewall.
Have you tried a packet capture?
Try using the local status page on the MR and see what it is reporting.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
Is it able to get an IP address?
Is it configured for a VLAN for management, but the switch does have a compatible configuration?
Is DNS working?
If any of the above three is broken you'll get no traffic at the firewall level.
