Change Log
Ahmed_Ayoub
Change Log
Hello guys,
I was wondering if it possible to verifiy who made a specific change on an SSID configuration, like for exemple if someone modifies 802.11w settings . I looked at the change log page but can't find it. Anywhere else i can search for that info ? Or maybe this kind of change is not logged at all ?
Thank you for your help.
On the change log, you are able to see all modifications.
Is it on data retention time?
https://documentation.meraki.com/General_Administration/Privacy_and_Security/Cloud_Data_Retention_Po...
Ahmed_Ayoub
I cannot find this info on the change log page, and its a recent change that has been made yesterday. I only can see like major changes (SSID enabled, port disabled/enabled ...). But for exemple if i made a change on the 802.11w settings on an SSID, i can't see it.
You're right, I tested It, have you tested It sending the log for a syslog server?
Brash
A quick test of enabling 802.11w on an said didn't log it as a change. Instead, it logged the change as "SSID PSK - value did not change".
Its feasible that it was enabled at the same time as other configuration was changed on the SSID (enabling/disabling, PSK change etc) and therefore the change got logged as that.
