MR 33 firmware update caused client connection failure
David_Wild
I upgraded our MR 33 from 25.x to 30.x and clients could not connect.
1 Reply 1
DarrenOC
Hi @David_Wild , are you able to expand on your issue a little more?
- what devices were affected
- OS
- what is the Auth method
- any errors in both the devices event viewer and Meraki dashboard
I presume at this point you’ve rolled back the firmware on the APs?
