MA ANT 21 H and V ports?
RumorConsumer
On the connectors there are labels called H and V for each connector respectively. The AP (MR74 in this case) has no such indications. Anybody know what they mean? Horizontal? Vertical? What?
BrechtSchamp
The horizontal & vertical planes as described in the datasheet: https://meraki.cisco.com/lib/pdf/meraki_datasheet_antenna_5GHz_sector_13dBi.pdf
This is generally how antenna radiation patterns are described.
Horizontal AKA azimuth plane
Vertical AKA elevation plane
Check this link for more info:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/prod_white_p...
RumorConsumer
Super cool: does it matter which R type antennas go into which?
BrechtSchamp
I'm not sure I understand that question. It's a 5GHz band antenna, so in the case of the MR74 it should be attached to the bottom two connectors (the band should be marked on the shell of the AP). It doesn't matter which one goes which.
