Limitations on number of devices per guest login
KatyDinwiddie
I would like to know if there is a limit to how many devices a single guest user login is allowed to have. I have "Allow simultaneous devices per user" chosen, but was curious is that unlimited as a default or is there a number that Meraki has for that?
jdsilva
It's unlimited on the Meraki side for this. You'd have to go to a RADIUS server to control simultaneous logins. Most RADIUS servers have this functionality.
jdsilva
KatyDinwiddie
Awesome, that's exactly what I needed to know. Thanks!
pyraja
It's unlimited by defaut but if you are using splash page then in dashboard select network -> Wireless -> Access control (select SSID) -> Advanced splash settings -> Simultaneous logins -> select limit to one user at a time (or) Allow simultaneous devices per user.
