License cw9162?
MauroF
License cw9162?
Easy question fo you guys: Whats the license CODE for the 3 years license for a CW9162?
Doing my BOM via Cisco site i cannot find the LIC-ENT-3YR.
Can you confirm it?
rhbirkelund
You may need to just “Hail Mary” it, and type in the SKU and press enter. The MR license has never been able to just search for it.
8 Replies 8
DarrenOC
Hi @MauroF , that should be the right part code. I’ve struggled with CCW today so maybe’s it’s having a slow day.
link to MR license info below:
https://documentation.meraki.com/General_Administration/Licensing/Meraki_MR_License_Guide
MauroF
i cannot find it....in the past im sure it was that...but now it seems like it changed code... cause
LIC-ENT-3YR i cannot find it.
DarrenOC
Must a CCW issue as I can’t find them either.  I can find the LIC-MR-ADV and -UPGR options however
rhbirkelund
rhbirkelund
Yeah, it's not searchable
But if you just press enter, it's added to the estimate.
DarrenOC
Disagree on the “never been searchable” bit as I’ve used plenty of times in the past.  However, I didn’t know you could Hail Mary and add. I’ve always waited till the item appears.
rhbirkelund
I have never been able to search the license, either in the results dropdown, or Find Products.
MauroF
In any case, thanks guys!
