Lenovo N22 Chromebooks
unplacedap
K-12 school district
Have MR-52 / MR-53 campus wide
Chromebooks NR 22  - Lenovo
Have had reports of Chromebooks receiving "unable to connect to a dhcp server."  Setting the Chromebook aside and waiting then the device connects.
DHCP address lease pool is never exhausted and historical history of AP's show no downs or interruptions. Problem seems to persistent according to the PC Tech.
Any ideas or suggestions?
Thank you
5 Replies 5
kYutobi
Check your "Wireless Health" and see where the part of DHCP fails. You can see more info there.
Enthusiast
Fairly new to the Meraki model...so thank you for the insight.
kYutobi
@unplacedap no worries my friend. That's what we're here for. 😊
Enthusiast
Is the SSID they connect to using internal or public DNS? If possible, can you test using Google DNS to see if they work.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Are there any statically configured devices in the same VLAN?
Any chance of DHCP conflicts or IP address conflicts happening causing DHCP to have to back off?
