- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Is My MR66 AP Using a Meraki PoE Injector or Only my PoE MS220 Meraki Switch ?
I inherited an already installed (10/2015) Meraki one building network. I have been doing the physical walk around inventory as well as using the Meraki Dashboard. Using the dashboard menus, I see no reference to any type of power injector. The MR66 APs are mounted outside up on the building so I can do a visible "reverse" search backwards.
Online documentation for the MR66 AP says ==> The MR66 access point can be powered using either a third-party 802.3af PoE switch or the Meraki 802.3af PoE injector (sold separately).
Why does Meraki documentation not reference using a Meraki PoE switch like my MS220 ?
Phil
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@ndccpf1 Correct devices powered using POE injector will not show they are powered this way in the dashboard.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Did it come out before Meraki PoE switches existed? The current install guide just mentions an af switch, not particularly a 3rd party one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Most likely that model was available before Meraki had POE switches in their lineup. The datasheet I have found mentions "Power over Ethernet: 24 - 57 V (802.3af compatible)"
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MR66.pdf
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I show the MR66 Release Date 14-JUL-2014 and I think the MS220 PoE line was selling before that date.
But I figure I'm good but I guess a PoE injector is not visible to the Meraki Cloud Dashboard even if I had them ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
