Intelligent Capture - MR (another new early access feature)
I saw this today and I am sure it wasn't there yesterday, so enabled and I'll attempt some bad roams...
"Intelligent Capture - MR: Proactive packet capture upon any wireless connection failure with cloud-based storage of packet capture."
It sounds like a very useful feature!
14 Replies 14
RaphaelL
Locked behind the new licence is a shame though
Not while it is in testing, so time to take a look and then campaign if needed 😁
RaphaelL
Trying to sell the new licence to my management , but the documentation is pretty new. Are you aware of other feature ( beta , private-beta ) that will be behind the new lic ?
Ryan_Miles
Meraki Employee All-Star
MR ADV has the following features today
  • Automatic Umbrella Integration
  • Adaptive Policy
  • 2 x MT Licenses*
After the beta period of Intelligent Capture (MR) and AI-RRM I believe those will also be added to the MR ADV list above and the doc will be updated accordingly.
MyHomeNWLab
"Intelligent Capture - MR" seems to be supported in version MR 31.1.3.
[Release note: Wireless firmware versions MR 31.1.3 changelog]
> New feature
> Intelligent Capture for Wireless Proactive packet capture support
Hmm, I've had a lot of issues with 31.1.3 and 31.1.4 dropping Android clients and not allowing them to reconnect, I'll upgrade again and hopefully this feature will help pinpoint the problem!
GIdenJoe
I tried to enable it but I only got the same page as the MS switch capture page.
So not the cool management frames proactive intelligent captures that what I was expecting.  Am I missing something?
I haven't found anything yet either...
Paccers
I enabled the trial via EA and got it straight away, from the Packet capture page once you change to 'For access points' it then refreshes in to the intelligent capture view for us
Thanks @Paccers , easy when you look at what is in front of you!
One issue I have found is that my MR55 (which doesn't support bi-directional captures), now doesn't support any captures...  If you have a mixed environment, then I guess you need to enable/disable the feature each time you want to switch between older and newer AP models.  Hopefully this will be fixed ASAP!
Already got an automatically captured trace of a failure to get a DHCP address for a client, it looks good when downloaded, but the in page viewer just sits there on the loading page.
Another AP auto captured and the viewer also fails with that.  A manual capture also only works when downloaded and opened locally in something like Wireshark.
RaphaelL
Same here. Some pcap can be viewed from the dashboard and some can't. Don't know why at the moment
Paccers
Looks like the Feedback button will be getting some use!
