Inhouse RADIUS Server Configure for Auth
rahul_sonawane
Want to configure the local RADIUS server with a Meraki access point? I have tried but when I add the Radius server in SSID and try to test getting fails but when I try to ping from AP to the Radius server, AP is ping to the Radius server.
2 Replies 2
DarrenOC
Hi @rahul_sonawane , whilst you may have IP reachability between your AP and the Radius server this isn’t enough to get this working.  Have you followed the Meraki Radius Auth Config guide:
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...
KarstenI
To summarize the most important steps:
Port UDP 1812/1813 (that you have configured on the SSID) have to be allowed all the way to the RADIUS server
The shared secret has to match on the AP and the RADIUS server
After that, you should have at least a log entry in your server when users connect. For me, the test function in the SSID config was never reliable. Try to connect a client and look at the server logs.
