IE Popup when connecting to SSID
tim829
On one of our corporate SSID's that uses PSK for authentication users recently have started to get a IE popup saying you have successfully connected to XXXXXXX network. Why is this happening? This didn't happen before and it's annoying! Was this do to an update or something?
1 Reply 1
Adam
Happening on multiple computers and multiple APs?  Any changes in your config or firmware recently?
