How to replace to cold swap MR
kawata2
I am considering replacing the wireless AP with a cold standby AP by following the procedure below.
Is it possible to replace it using the same procedure?
  1. remove MR device from cloud portal.
  2. add new MR (cold standby).
Regards,
DarrenOC
Hi @kawata2 , really is nothing to it. Literally just swap the physical device over with the new one.
Dont forget to remove the old AP from the network and unclaim it
https://documentation.meraki.com/zGeneral_Administration/Inventory_and_Devices/Adding_and_Removing_D...
CptnCrnch
In a nutshell: yes. That's the beauty of Cloud based management 🙂
kawata2
Thank you for your reply.
I was relieved that I heard that.
DarrenOC
kawata2
Thank you for your reply and your advise.
