- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How to find and disable overrides ?
I am new to this company and on the profiles is says
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Sounds like the previous admin has made bulk overrides to the RF settings for your AP's.
Under wireless -> RF settings you can see/change the profile used by your AP's. You. An also override some of these settings by selecting the AP's and clicking "Edit Settings" -> "Bulk edit settings..."
My guess is that they've manually overridden channel assignment or power. 90% of the time these settings take care of themselves on auto but in some circumstances these can be manually tuned for better performance.
You can clear overrides by re-assigning the profile to the AP. Select the AP -> edit settings -> assign profile, select the profile and on the next page, check the boxes for clear overrides. The review page that follows it will then tell you the changes it's about to make.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Or they forced a setting on each ap manually. (Channel, channel width, power)
Or if they changed something in the profile itself, for example : 5 Ghz Channel width: from auto -> manual 20 or 40Mhz(Most Likely with 104 ap). Then its also called overide.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I will go in and apply the basic profile to all and tell it to clear the overrides. So many things I found wrong who knows what they did!
