How to assign manual IP address to MR-46
Mohit_Dhanjal
Hi Team,
I have new MR-46 access point, i want to assign manual IP address to this AP, i have connected the same with my access switch.
I don't have DHCP configuration in my switch, Without DHCP configuration through my laptop Can i assign manual IP to this AP.
Also please suggest other method's.
Thanks & Regards
Mohit Dhanjal
8 Replies 8
Ryan_Miles
Mohit_Dhanjal
Hi Ryan,
Thanks for the update, i have already gone through this document.
My question is if DHCP is not working, which IP address i need to assign to my laptop, so that i can access AP local login page to configure manual IP.
Regards
Mohit
Mohit_Dhanjal
Hi Alemabrahao,
Thanks for replying.
Do i need to connect my laptop and AP to same switch for this procedure. Also Switch that i am using is Cisco 9300 switch, do i need to perform any configuration on the same as well.
Regards
Mohit
Just put both on the same VLAN
Mohit_Dhanjal
Do i require internet access when assigning manual IP's to access point. or without internet i can assign manual IP by connected laptop and AP in same VLAN
Mohit_Dhanjal
You don't need internet access, you just need to configure the static IP on your machine and access the AP via IP 10.1281.28.126.
