Hotspot 2.0 on MR33
Srinivas
Hotspot 2.0 on MR33
We were looking to test the Hotspot 2.0 functionality of meraki access points. The only guide to this I found was this https://documentation.meraki.com/MR/Other_Topics/Hotspot_2.0
Hence had few questions on this.
1) Is the MR33 passpoint certified to support HS2.0?
2) The guide says that the configuration is hidden for simplicity, how would I access this configuration?
3) Which meraki device could also be used as the radius authenticator for this? This server would also have to host a webpage from which the client could download the certificate suited for his/her mobile phone/tab. Also does it support all device i.e android, iphone, windows?
Thanks & if there is a better guide out there do post the link.
2 Replies 2
jdsilva
1) Yes
2) Call support and they can enable it for you
3) The AP's are all authenticators. What I think you're asking here though is what can be the Authentication Server, and the answer to that is whatever you want it to be. But there isn't a Meraki Product for this component. You will need to source your own Authentication server that supports HS2.0.
SoCalRacer
https://documentation.meraki.com/MR/Other_Topics/Hotspot_2.0_Configuration_Example
This feature is currently in a service provider-only closed beta.
So that sounds like it probably won't be happening for you unless you are a Service Provider
