Help with Port Profiles on MR36H
RayR
I'm trying to set up port profiles on an MR36H - but I'm confused.
The dashboard config settings list Ports 1 through 4 - BUT the device has an "unmanaged" port and three other ports (numbered 1 through 3).
So - I am confused.  Can I actually put a port profile on the unmanaged port?  And, if so, is it considered port 1 or port 4?
TIA
Ryan_Miles
Meraki Employee All-Star
Yes, this doc explains it https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Port_Profiles
"MR36H will use a 4-Port profile (same as MR30H), however, port 4 of the profile will not be used since the port does not exist on the AP. For more information about MR36H ports please visit installation guide."
Brash
Do you have a screenshot of what you're seeing on the dashboard?
According to the installation guide, the ports are as follows (leftmost is the passthrough, and the LAN ports follow after that)
RayR
Dashboard view:
RayR
Never mind - Found my answer:
Ryan_Miles
