Help reset
dung44
Help reset
Please help reset meraki outdoor. There is no reset button
2 Replies 2
Factory reset button
The factory reset button is located in a small pin-sized hole just above the PoE Ethernet port of the MR74.  If the button is pressed and held for at least five seconds and then released, the MR74 will reboot and be restored to its original factory settings by deleting all configuration information stored on the unit.
SoCalRacer
