So now that the fall creators update is out, I was excited to try out 802.11r on a handful of our machines.
So - I created a new SSID, enabled 802.11r, joined a few Win 10 PCs to it, but, all I see in the dashboard is 802.11r: Off
Called into support - and they said it should be enabled by default. I've verified with Intel that the adapter supports 802.11r.
I cant seem to find anywhere online of any steps I need to take to enable fast roaming. Has anyone gotten it to work?
*Edit - I've made sure to update all PCs to the newest ProSet driver from Intel.
