Guest WIFI with Mx Concentrator
SJB1
Best performance for MX100 and Guest WIFI.  VPN tunnel or Layer 3 Tunnel to concentrator
Ryan_Miles
Both modes use the same underlying AutoVPN tunnel. The only difference between these modes is VPN allows for split tunneling. The performance should be the same in either mode.
DarrenOC
Hi @SJB1 , I’ve used the wifi concentrator mode seamlessly numerous times
DarrenOC
Assume you’ve read this
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/SSID_Tunneling_and_Layer_3_Roamin...
Ryan_Miles
