FortiAP
rodeddie
FortiAP
I'm looking for battlecards on Fortinet wireless, something on AP's, dashboard
6 Replies 6
I don't understand your question, but here is a community to talk about Cisco Meraki products.
rodeddie
I'm working on an opportunity that is looking to change their fortinet solution and i'm  looking for documentation on comparisons with FortiAP and Meraki,
There is no documentation comparing the vendors. The easiest way is to get the datasheet for each of the solutions.
Take a look at this.
https://www.saashub.com/compare-cisco-meraki-wireless-access-point-vs-fortiap
But remmember, it's not a official documentation.
rodeddie
Thanks, it's something
Brash
Assuming you're a Cisco reseller/partner, battlecards can be found in the partner portal or on salesconnect (linked below). Failing that, check with your Meraki rep.
https://www.merakipartners.com/
https://salesconnect.cisco.com/
