Forced Upgrade on MR46s WAPs firmware to 29.5.1 intermittent down
AndrewMoore
After a forced firmware upgrade. I am seeing intermittent WAPs going down seems to be about every 2 hours. All sites having the issue have a public routable IP address. the other half on a private 10.0.0.0 network are not having this issue. Last time this occurred we had to revert back to firmware model 27.1.
model MR 46
Firmware 29.5.1
this version is considered "stable"
I found this
[6:42 PM] Andrew Moore
https://community.meraki.com/t5/Wireless-LAN/New-MR-29-1-Beta-new-release-chain-with-WPN-more-IPv6-n...
known issues AP may loose Cloud connectivity for an interval time.
7 Replies 7
Have you tried version 28.7.1 or 29.4.1? Otherwise open a support case.
rhbirkelund
@AndrewMoore wrote:
I found this
Correct, but that bug should be fixed in MR29.2.
Do you have an upstream firewall, which may be blocking ports to Meraki Cloud? You can see the required openings by clicking on Help -> Firewall Info.
Otherwise you should submit a ticket to Meraki Support, as @alemabrahao suggests, and have the issues logged.
AndrewMoore
yes , but all my APs go through the same firewall and half of the meraki are fine with no problems the upgrade.
@AndrewMoore it could be that the upgrade hasn't completed successfully, try rebooting one of the APs that keeps going offline and if that doesn't work downgrade the network to an earlier version and check your firewall rules are allowing all the relevant ports.
AndrewMoore
thats the first thing i tried. i rebooted all of the APs having this issue. and then i double checked the IP addresses didnt change so the firewall wouldnt be the problem.
Ryan_Miles
Meraki Employee All-Star
Go to Help > Firewall info. It shows you have devices failing the routine firewall tests. It also includes a csv with the list of which devices are failing. This means the devices cannot reach the required destination IPs in the Meraki Cloud.
https://documentation.meraki.com/General_Administration/Other_Topics/Cloud_Maintenance_New_IP_Ranges...
