Failed connection - unspecified radio
AnM
Hello.
Recently having problems with industrial tablets that are trying connect to wifi on locations. In logs i can see
This is both on firmware 30.7 and 30.7.1. I have MR36 on locations. I can't seem to find any informations about this specific reason.
I would be gratefull for any kind of tips/help. Thanks
WPA3 has terrible compatibility at this point in time.  Try using WPA2 instead.
If you want to use WPA3 setup a seperate SSID for it.
5 Replies 5
GreenMan
Meraki Alumni (Retired)
Just to be clear - it doesn't say 'unspecified radio' - this event is being seen across two radios;   2.4 GHz (radio 0 [channel = 1]) and 5 GHz (radio 1 [channel = 36])
The reason is unspecified.
I would check whether those client devices of yours support WPA3.  This technology is usually associated with 6 GHz W-Fi 6E and later - and require specific client side support.   My guess - based purely on the radios mentioned here - is that the Meraki APs may not support 6 GHz either.
AnM
Right now this specific SSID is set, as shown
So if i'm understanding it correctly it should work fine. Configuration wasn't changed since the date it was set first time. It was working in the past without any problems, but i can't pinpoint exact date, when it stopped working correctly.
Echoing what @PhilipDAth said, WPA3 Transition Mode is useless and should be avoided at all costs.  WPA3-PSK is much better, but will still generate some issues particularly with Android devices in my experience.
AnM
Yeah so in my case (these industrial tablets were with android 13), switching to wpa2 only solved the problem. Thanks
