Disable Syslog security events for MRs - Is it possible ?
BazMonkey
Morning friends.
We have syslog reporting to SIEM and all our MR access points are currently configured for DHCP so often their IPs can change on reboots etc.
Our SIEM server does not like devices changing their IP addresses as it keeps reporting them offline when they change IP and then the security team complain when they come up as a new device.
Is there anyway to disable or filter out security syslog events from MR's but keep them for the MX?
Else I'm going to have to get reservsations setup or fixed IP and we have hundreds out there so not something I'm in a hurry to do.
Have a great day. Nearly the weekend 🙂
7 Replies 7
BrandonS
I don't think so.  It seems more the job of the SIEM to filter and ignore unwanted messages though.  If you are using an MX as DHCP server you can import them in one .csv file.
BazMonkey
Hi Brandon.
What firmware are you using for the MX in the above screen grab.
We don't get the option to import via CSV and have to manually add reservations.
We are running 15.44
I thought it was a dashboard upgrade when that option first appeared but seems linked to the firmware version.
Ryan_Miles
Doesn't work with templates/template bound networks
Ryan
BazMonkey
Ah right. Did wonder how i've seen it somewhere before. That's a pain.
I did write an API pyton script to add them but every line just kept overwriting the last entry so it failed. Maybe I need to make a single call per entry or learn Python better.
Ryan_Miles
Actually it might work with templates under 17.5 beta. Testing now.
Ryan
BazMonkey
Good to know it's being looked at. I often have to added 40 - 50 devices on some sites.
Ryan_Miles
Ok, so I think it only works in templates when the VLAN IP schema is using "same". If using "unique" then it's not shown. And it's not something available as a local override outside of the template for a template bound network.
Ryan
