Disable SSID for a single Network when using SSID Template
greaper
I have all of my SSID's controlled by an central SSID template.  Can I disable a specific SSID for a specific Network by using the "Access Control" functionality?  Will that disable the SSID for all of the Networks that are using the template or just the one Network where I disable it under "Access Control"?
jdsilva
As long as you are under the actual network (and not the template)  it will disable the SSID for just that network.
1 Reply 1
jdsilva
