- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Different APs models.
Hi all,
is advisable to mix different access point types in same enviroment?
In my case MR46 are already present 2xfloor and i'd like to add 2xfloor CW9166 or CW9164.
thanks for suggestions.
Regards,
MG
Solved! Go to solution.
- Labels:
Installation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In general, they shouldn't be mixed. But in your case, they are both WiFi6 with quite similar characteristics. Here I would say it is generally ok if you don't use 6GHz. But with 6GHz I have no idea how they behave.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Definitely not. CM's are 6E and the rest are 6. As a rule of thumb, you should not mix APs unless they are similar in band and number or radios/channels... or not at all. For example, you could safely blend MR36H into an existing MR36 installation without issue. I have had problems with a mixed mesh of all MR36 and one MR46 that caused problems with roaming. This was likely due to a difference in the number of radios in the APs... you want to go for homogenous and contiguous.
