Delete more than 100 users per month
MichelRueger
Hi All,
WE are Using Meraki AcessPoints for Public Events. Now we have a problem. the Dashboard only accept do delete 100 User Data per Month!! Why???
After an Event, we are legal pushed to delete all user Data in the Dashboard. Now if I go to the Dashboard  on Clients and select them all and click on forget the Dashboard tells me that I can only delete 100 User per Month!
Why, is there any reasonable reason???
IS there a way true API to delete them all?
Thanks for any Help
BrechtSchamp
There's a specific API call to remove PII (Personally Identifying Information). It was added due to GDPR regulation. Check if that helps your case:
https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm#b7c77f0c-51e2-4ad5-9bef-d1...
2 Replies 2
I would just create a new network which is a copy of the old, move the kit, and delete the original.
If this is an MX and is not a combined network you can also change the client tracking type from MAC to IP and back to MAC to wipe all client statistics.
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Client_Tracking_Options
BrechtSchamp
