Custom Alarms - SSID and MAC level
gcarmich
I'm a basic user of Meraki Dashboard.
I need to monitor a specific SSID and client MAC(s) to see if they go off-line.  I'd also like to see daily usage and other stats.
I created Alarms for the SSID and MAC but now I can access them on the Alarm Configuration page.  Is there a better way to track this information?  How can I modify and alarm I created (going to my email)?
Thanks,
Gil
If you have an MX, this will be easier to do using a network alert.
There is nothing that will send daily usage for a single client.  You would need to go into the dashboard to see that.
You can schedule a summary report that shows the top "n" users.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Summary_Report_Overvi...
2 Replies 2
gcarmich
Our APs are MR series.
I setup an alert but now I cant find it.
Maybe the API is a better way to go?
