Correct install position AP MR76 with antenna
RG
Hi everyone!
I'm installing MR74 access points using antennas omnidirectional (MA-ANT-20) in a warehouse, I'would like to know what is the correct position for better coverage:
opc 1 : Antennas and access points vertical
opc 2 : antennas and access points horizontal
2 Replies 2
KarstenI
These antennas are typically installed in a way that they point up and down:
https://meraki.cisco.com/product-collateral/dual-band-omni-antennas-4-7-dbi-datasheet/?file
But in a warehouse, the narrow patch antenna is often a better fit (but with a different AP):
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MA-ANT-3-F.pdf
RG
Thank @KarstenI
I've installed the antennas as you mention and the network are working fine with very good signal
